-   CBR 954RR (https://cbrforum.com/forum/cbr-954rr-21/)
-   -   High Beam won't come on- (https://cbrforum.com/forum/cbr-954rr-21/high-beam-wont-come-111372/)
obmonger May 28, 2010 11:45 PM
So one day after coming down a bit hard from a wheelie, my high beams stopped working. They had been acting up before that, as in I would have to flip the switch on and off a few times once in a while before they worked. But now, nothing.
Here's what I've tried so far:
I plugged the lights themselves into the low beam light to make sure they worked, and they do.
I tried to use just one of the 2 high beams at a time, and nothing. EXCEPT, one time after messing with the wire harness I plugged the left side in and it worked, but then I plugged the right side it and it stopped again, never to come back.
I switched the relay that is located under the passenger seat to one of the other relays and thats not it. I can hear the relay switching when I flip the hi/low switch.
With both lights unplugged the blue high beam indicator light comes on as it is supposed to. ( I leave them unplugged all the time cause sometimes my starter switch gets stuck 'in' and thats the only way I know its not 'in' and the starter is not going.) But when I plug the High beam back in, the blue indicator light goes out.
I went through and try to wiggle the connections to see if something was loose, but electricity is not my strong suit.
Any ideas?
DjChrisChip Jul 12, 2010 05:58 AM
on my bike tht i crashed i noticed this starting to happen as wel hope some1 can help me figure it out
