Help Starting issues 954
My bike refuses to start and it displays f1 on the dash board yet the battery Is fully charged.. Please help
The FI light should be on with the key on engine off for a few seconds, then it goes off. If it's stays on, jump the diagnostic connector and read the code to see where to look next.
The fi light is off but yet the bike won't start . if you switch on the starter switch the fuel pump primes but after that nothing happens
does the starter crank it over?
No its not cranking at all...I really don't understand what's going on
No cranking even the fuel pump is not priming any more.
Will it bump start?
I will probably try that. I checked the fuses and all of a sudden the fuel pump isn't priming any more.
sounds like an electrical short possibly in the ignition switch itself. Hard cycle the switch on/off a couple of times and try again.
