help, no start on my '02 954
I've had this 9600 mile bike for a month and I absolutely love it. It is the sweetest bike I have ever owned.
Went to the grocery store yesterday, ran in and grabbed some cold ones, returned and the bike would not start. I don't recall hearing the fuel pump making the cool noise it usually makes, cranked over normally, but absolutely no fire in the cylinderes, could not smell any fuel in the exhaust. Safety switch, passive anti theft, tip switch? I tried kickstand up down, cycling the kill switch on and off, run starting, nothing. I did place something in the trunk under the seat, but I couldn't see any loose wires or connections. HELP!! Thanks in advance.. |
RE: help, no start on my '02 954
hmm sounds wierd, it cranks.. but no fire.. no noise from fuel pump..could be fuel pump, there is the relay for fuel pump in the rear i believe so maybe u hit that but i highly doubt that, take it a part about and check spark
o ya, what about push start?
Yeah, I did try push starting it too, absolutely did not want to fire over. Funny, but I didn't even realize that there was no fuel pump noise until I was driving to work this morning!! I kinda like the way it whirrs to life before you crank it. Anyone had a fuel pump go bad on one of these? How much to replace?
depends, you are going to do it yourself right..
http://cgi.ebay.com/ebaymotors/HONDA...spagenameZWDVW
go there, 50 bucks for a fuel pump, takes an hour or less, real easy |
i had the same problem happen twice.. first thing to do is check all fuses. there is one main 30A fuse that is beside the fuse block. iff it blows nothing will work. if all the fuses check out straight wire the fuel pump. you have 3 wires to the fuel pump. two hot wires and one ground. straight wire the two hot wires off the batttery and see if the pump primes. If it does youve narrowed it down to probably one of three things.
There is a wire on the right side of the bike, as if youre sitting on it, that runs in the main harness. pull off the right side fairing and you will see a big wiring harness towards the radiator. unplug it and make sure none of the connectors in the plugs have burned up or melted. i had one burn up that was caused by a bad connection. my bike would come turn on and turn over but you never heard the fuel pump prime and it wouldnt start, horn and signals and brake functioned properly. The rollover switch connector might be corroded. mine was. it is located behind the main upper fairing. take it off check the connection between the two. theres a way to test it but im not sure how to do that, other than replace it if you cant figure anything else out. Fuel pump relay is located on the tail section on the right side, as if you are sitting on the bike, its like 15 bucks from the dealer. you can test it for continuity. Other than that i dont know what to tell you. all of these things have happened to me and cause the bike not to start so hopefully one of them helps you. |
Thanks blade runner, that is good info. In the last hour I have tested the fuel pump relay (fine), and determined that there is no juice at the fuel pump connector. I guess it is good news that the pump is probably OK. I will try the tipover sensor tomorrow. I called a local cycle shop and they have them (used) for $20. I appreciate you taking the time to jot this stuff down. Hopefully I can get it going tomorrow.
good luck, kinda forgot about the fuses's but most likely that is all it is, a friend had it happen to his F4i
ORIGINAL: 03bladeRunneR There is a wire on the right side of the bike, as if youre sitting on it, that runs in the main harness. pull off the right side fairing and you will see a big wiring harness towards the radiator. unplug it and make sure none of the connectors in the plugs have burned up or melted. i had one burn up that was caused by a bad connection. my bike would come turn on and turn over but you never heard the fuel pump prime and it wouldnt start, horn and signals and brake functioned properly. |
