Help With My 954
That almost sounds like what mine was doing when the FPR went out on it but it was the #2 and #4 cylinders I believe. I had fuel pouring out of the header where its connected to the mid pipe, I have a full Erion Racing system. Here's a link on checking it https://cbrforum.com/forum/how-103/h...ulator-129704/. But since its only on the #1 cylinder I doubt the FPR is going to be the problem. Let us know what you find out.
Yep same symptoms and inspected mine and sure enough its leaking fuel out the end of it as in the video above. it must of been leaking so much fuel out that it would just run back through the vacuum line and fill the cylinder that way. got one on order so hopefully thats all it is. I appreciate everyones help. Ill post back up after i get the new reg.
