headlights quit working??
Old 08-26-2006, 01:29 PM
bobjoezx's Avatar
Default RE: headlights quit working??
no take of the seat and test it at fuse box.. and see if ur getting it from there , i know u said the fuse wasn't blown but just try putting a new one in there after u test it and see what happends
Old 08-30-2006, 01:46 AM
02_954rr's Avatar
ok so i have power at the fuse box none up front,you think it might be in the headlight switch?
Old 08-30-2006, 01:58 AM
bobjoezx's Avatar
check the wiring..
Old 08-30-2006, 11:40 PM
it mayb the switch but check make sure the switch is gettin 12 volts(power) to it then it will b the swtich....if not u gotta open wire...hope u get it done
Old 09-01-2006, 09:32 PM
02_954rr's Avatar
Default RE: headlights still not working??
i tried all your guys tricks with nothing
Old 09-01-2006, 09:50 PM
bobjoezx's Avatar
take the plug out of the headlight, check it at the connection point in the connector when u turn the bike on
Old 09-02-2006, 05:10 AM
02_954rr's Avatar
i have done that nothing can one little wire rub clean inside??
Old 09-02-2006, 03:47 PM
tail lights are working-correct??(they use same ground as low-beams-l/beam lights have to work in order for h/beams to
work)-start with low beams-remove connector from bulb-ground volt meter/test light to battery-probe l/beam
connector at grey wire-should be 12 volts-this is supplied buy the engine start/stop switch-is 12 volts present?
if not check black/red wire at start/stop switch connector-if 12 volts are there-check white wire at same
connector-should have 12 volts also
post results
o8
Old 10-11-2007, 10:59 AM
teamneon's Avatar
well i would rather dig up an old post by searching than to post a new question...thats the exact same problem. lol
I have done a voltage check, power at fuse, all wires into low and high beam are grounds!?!
i took the highbeam switch apart and kinda looked at it but didnt test the voltage DOH!
bulbs are new, bike was fine in the morning, no headlights at night but tail and blinkers fine.
i ran a heavy gauge wire to a toggle switch and then to my low beam so i could ride until i figure out whats wrong.
should the voltage be 12-13v at the switch or what? ill check that tonight.
also, what side of the tank does the wiring harness run?
Old 10-11-2007, 01:19 PM
CBRinPDX's Avatar
Have you checked the headlight relay? The realay is between the fuse and the lights, circuitry wise, since you have power at the fuse box and your fuse is good then logically the relay is dead.
Quick Reply: headlights quit working??
