Headlight bulbs....
Okay so everything I'm finding says that our high and low beams are both H7 bulbs, and they look like h7 ... Ordered some H7 bulbs from amazon... their little "does it fit" tool even showed it was the right bulb ...
New bulbs arrive and the prongs for the connection are significantly closer to one another than the bulbs I took out.... 1/4" or so... Obviously, they wont plug in. The housing seemed a little small too so it didn't feel like it really seated in well.
My question... Are there different spec'd H7 bulbs that I need to make sure I get the right ones or is the set I ordered just made wrong?
No adapter, just the plug.. But looking at it, it almost looks like an h4 plug that is just missing the 3rd connection... However the bulbs in the housing don't have dual filaments so they aren't h4
You're missing adapter #4
https://www.ronayers.com/oemparts/a/...27/headlight-2
part # 33130-MAT-611
H7 on inside and H4 on outside to plug into harness socket
https://www.partzilla.com/product/ho...saAtf4EALw_wcB
I haven't tested it myself yet. I did get led bulbs that were designed to be halogen replacements so the focal point of the bulb is the same position as the standard bulbs so it SHOULD be a clean cutoff line... But I wont know for certain until I get it out and test it.
When I swapped the bulbs on my Expedition I made sure to get bulbs designed as halogen replacements and The cutoff was clear and crisp and at the same point as the OE bulbs so I'm hoping for the same. I have no interest in blinding anyone or giving anyone x-rays in my endeavor to see well.
