-   CBR 954RR (https://cbrforum.com/forum/cbr-954rr-21/)
-   -   Getting stock lowering link off! (https://cbrforum.com/forum/cbr-954rr-21/getting-stock-lowering-link-off-77353/)
djblaze247 Sep 4, 2008 04:02 AM
Need some tips on getting the actual stock link off my 954, I ordered the link and not the triangles and ran into a slight speed bump. I can't get the stock link off because the I can't slide the upper bolt out because it hits the exhaust bracket which is a part of the actual bike frame. Any help would greatly appreciated.
not_agn Sep 4, 2008 09:59 AM
RE: Getting stock lowering link off!
I pushed the rubber grommet out and the bolt should fit through. Of course I had a micron full system so I didn't use that mount anymore. If you have the stock exhaust you just need to move it out of the way and remover the rubber. Then reinstall and mount you exhaust.
Bert Sep 4, 2008 01:33 PM
yeah i did the same thing you need to get the rubber piece off and it will slide through.
djblaze247 Sep 8, 2008 11:09 AM
Thanx for the tip, that worked perfectly, my link also has a 4 inch setting but I can't get it there because the shock hits the link at that point so I have it dropped 2 inches. any tips of how to get it to the 4inch setting?
