Gearbox overhaul - not for the faint hearted? Advice please 🙏🏻
Old May 27, 2023 | 06:52 AM
TheScissorman's Avatar
Default Gearbox overhaul - Advice please 🙏🏻
OK, so today isn’t a good day. New helmet arrived this morning and it’s too small. Then took my bike to a mechanic with years of experience on blades and who works at TT to find a fault. He took it for a test ride and confirmed fourth gear is buggered, dogs, teeth or gear fork. Gutted as the cost to repair is huge.
My options are:
1 - Sell the bike as is with the fault.
2 - Get it fixed £1500+
3 - Get my head stuck into my Haynes manual
I mechanically minded, I was a mechanical engineer in the Royal Navy.
If I decide to do this myself, do you think it’s a doable DIY job?
Best place to purchase gears in the UK (2002 CBR954)
TODAY WAS GOING SO WELL!
Old May 27, 2023 | 08:34 AM
rockpool's Avatar
Haynes manual, time and patience, and you can do it. I don't know the exact parts compatibility but I saw in eBay some complete gearsets for sale, but the individual parts are not too expensive either.
There's this transmission in the USA where I am - 2nd is bad, but apparently the rest are good. https://www.ebay.co.uk/itm/266054147...Bk9SR-7HwNaLYg
What happens if you take the transmission shafts out and it's overwhelming? Just give it back to your mechanic - can't possibly increase the cost? Tell him "I want to try to fix this myself for ****s and giggles - if I get overwhelmed, does your quote still stand?"
Old May 30, 2023 | 11:41 AM
backdoc's Avatar
It's easy to remove the clutch and oil pan to remove the shift drum, forks and shift shafts to see what's the problem before splitting the cases.
https://cbrforum.com/forum/how-103/c...cement-151699/
https://cbrforum.com/forum/cbr-954rr...ission-152834/
Old Oct 16, 2023 | 01:06 PM
dimixalis's Avatar
Default How did this job go?
Did you get the transmission repaired?
Old Oct 16, 2023 | 10:40 PM
dannoxyz's Avatar
Transmissions are easy. Most helpful is Honda factory service manual for your particular model. It helped me rebuild engine when I was 17-yrs old and all I had done before was change skateboard wheels!
Do not use Haynes or Clymer manuals, they're full of errors!
Abs`
Mar 26, 2013 04:15 PM
HAVOC
Aug 11, 2008 10:19 PM
Sand.Man
May 5, 2008 08:58 PM
Grlzridet0o69
Feb 13, 2007 04:59 PM
