Fuel Pump keeps running when key is turned on
Ok hope someone can help me. I recently put a new battery in my bike. Now when I turn on the ignition key, the fuel pump starts running but then does not stop while the ignition is turned on. The bike starts up and runs fine but Im just not sure why the fuel pump doesnt run for two seconds like it is supposed to then turn off. Any help is greatly appreciated.
Thanks. |
fpr is on it's way out
Pull the vacuum hose off of the fpr and see if any fuel leaks out. If it does, ur looking at around $95 to buy a new one and replace it.
Thanks guys. The fpr is located where and what does it look like? Im guessing fpr stand for fuel pump relay? Thanks again
Thanks. Where is the best place to find one?
Fuel Pressure Regulator.You find them on bikebandit.com ronayers.com or even dealer
the fpr is located on left side of the fuel rail. it has said vacuum line on it.
looks like a tiny keg
Originally Posted by Conrice
(Post 1143240)
hahaha, it could be i'm just in need of a beer....
it looks more like a mushroom i guess..... wow... ...long day... carry on |
| All times are GMT -5. The time now is 04:06 AM. |
