-   CBR 954RR (https://cbrforum.com/forum/cbr-954rr-21/)
-   -   Front Headstock Paddock Stand ? (https://cbrforum.com/forum/cbr-954rr-21/front-headstock-paddock-stand-138074/)
Hudson May 14, 2012 01:50 PM
Does anybody use one of these ? If so what are they like, are they easy to fit and what size pin do you use ?
Conrice May 14, 2012 03:58 PM
headstock stands are a pita. many people however do use front axle stands
LasVegasHarley May 14, 2012 04:31 PM
I have the pit bull front triple tree stand. the 954 requires you to unbolted the 8mm bolt that holds the front brake lines to the triple tree. Yes, it is a pain in the ass.
letsride May 14, 2012 09:17 PM
I have and use one from DMP comes with a few different pins.I don't have an issue lifting it.
backdoc May 15, 2012 06:51 PM
I have a set of T-Rex Racing stands that I use very often. Never had a problem using the front triple tree stand and nothing had to be removed to use it either.
Hudson May 16, 2012 02:55 PM
Interesting.... very different experiances, i currently have an ABBA stand and have the Abba front lift as well, but this front lift thingy is a real PITA, it does not really feel secure because our bikes do not have two exhausts running parallel, so i had thought of getting a front paddock stand to lift the front and have the ABBA stand lifting the rear etc.
skip954 May 16, 2012 06:16 PM
i use a lochart phillips pin stand, it works good but will scratch the front fender.
ajzcamaro May 16, 2012 10:29 PM
You shouldn't be lifting the front unless the rear is already on a stand. Then it shouldn't be an issue lifting the front.
letsride May 17, 2012 06:05 PM
Didn't think about asking if he props the rear first and then lift the front up.
REAR MUST BE LIFTED FIRST BEFORE YOU CAN LIFT FRONT.
