Front Headstock Paddock Stand ?
Old May 14, 2012 | 01:50 PM
Hudson's Avatar
Default Front Headstock Paddock Stand ?
Does anybody use one of these ? If so what are they like, are they easy to fit and what size pin do you use ?
Old May 14, 2012 | 03:58 PM
Conrice's Avatar
headstock stands are a pita. many people however do use front axle stands
Old May 14, 2012 | 04:31 PM
LasVegasHarley's Avatar
I have the pit bull front triple tree stand. the 954 requires you to unbolted the 8mm bolt that holds the front brake lines to the triple tree. Yes, it is a pain in the ***.
Old May 14, 2012 | 09:17 PM
letsride's Avatar
I have and use one from DMP comes with a few different pins.I don't have an issue lifting it.
Old May 15, 2012 | 06:51 PM
backdoc's Avatar
I have a set of T-Rex Racing stands that I use very often. Never had a problem using the front triple tree stand and nothing had to be removed to use it either.
Old May 16, 2012 | 02:55 PM
Hudson's Avatar
Interesting.... very different experiances, i currently have an ABBA stand and have the Abba front lift as well, but this front lift thingy is a real PITA, it does not really feel secure because our bikes do not have two exhausts running parallel, so i had thought of getting a front paddock stand to lift the front and have the ABBA stand lifting the rear etc.
Old May 16, 2012 | 06:16 PM
skip954's Avatar
i use a lochart phillips pin stand, it works good but will scratch the front fender.
Old May 16, 2012 | 10:29 PM
ajzcamaro's Avatar
You shouldn't be lifting the front unless the rear is already on a stand. Then it shouldn't be an issue lifting the front.
Old May 17, 2012 | 06:05 PM
letsride's Avatar
Didn't think about asking if he props the rear first and then lift the front up.
REAR MUST BE LIFTED FIRST BEFORE YOU CAN LIFT FRONT.
Hudson
Feb 22, 2013 08:55 PM
Hudson
Feb 18, 2013 02:29 PM
Hudson
Aug 5, 2012 03:48 PM
Hudson
Jul 31, 2012 04:54 PM
Hudson
Jun 6, 2012 07:33 AM
