Excessive lever travel front brake.
I allways do it the normal way but i have vacuum pump that i use. I never bled any brakes more then few minutes and it has allways worked fine. The Brembo master i have is very easy to bleed. It has it's own bleeder and when the master is bleeded the calipers take minute per side more. But if i ever have a problem i'll try it the other way
Since then, I've done a KZ1000 (zx11 master), Bandit, and Buell M/C with the reverse bleeder, and it was a piece of cake.
I'm using a brembo unit off of a 1098 (I'm pretty sure it's the same spec master as the RC8, just a different color), so I'm excited to see how it works with the bleeder on the master - it'll be the first time I've ever used one. Glad to hear it was easy
I always liked the front brakes of the 954 but the setup i know have is "noticeably"
better. The 18mm Brembo unit is the best stock master i have tested so far. Haven't tried Panigale etc. that have top of the line Brembo masters but compared to japanese bikes stock masters.
I think you will really like it
Update on lever travel issue.
After reverse bleeding etc., and no improvement. I decided to pull a caliper off and go through them one more time. I held the caliper in my hand and slowly squeezed the brake lever. Lo and behold only one piston moved at first. After it was halfway out the second piston on that side of the caliper started to move. It came out partway and then popped back into the caliper!. I haven't seen that happen before.
So I methodically pressured each piston out one at a time and cleaned them and lubed the piston with fresh brake fluid until they moved freely. Pretty much all of the pistons were sticking to the seals to a degree. This is what caused the lever travel issue. After the clean and lube my front brake was as good as any of the other bikes. As a side note they had been cleaned and rebuilt only some months ago and the pistons lubed with a silicon based grease designed for pistons/calipers along with the new seals. I think I will stick with using brake fluid on pistons/seals going forward at least on the Honda. On my ZRX 1200R the grease worked great. Perhaps I didn't use enough or it was an anomaly.
Anyway I thought I would update you guys in case anyone else has a similar issue.
