Dyno run and full remap on 954
1 Attachment(s)
I did a Dyno & full re-map on PC 111 usb last weekend at Sabin performance
in dallas tx. 1st run before re-map was getting 128 hp & 65 ft lbs torque the air fuel mixture was a lil up and down but not too far off After a full re-map it peaked at 136 hp & 68 ft lbs torque no to bad for a stock 12 year old bike with 20k miles Attachment 24347 Installing a Dyno Jet quick shifter next weekend so ill update the outcome and performance afterwards Attachment 24348 |
1 Attachment(s)
Wow, that's quite an increase. I bet the bike is a lot easier and more fun to ride now.
Not to shabby I need a dyno close to me and see what they can do. Keep it up!
Nice air/fuel mix. I had to take a peak at my graph after seeing yours. The 954's are bastards from 4-5.5! They never want to lay down. Its hard to find shops familiar with tuning these bikes. It looks like you found a good one! For reference. I wanted a flat as possible air/fuel curve. I ended up with 141.81 HP and 68.36 for Torque. Modified air box/BMC filter and full race Akro. Your #'s look good!
Thanks ironhead, I'm pleased with the results especially since I'm running stock filter and header and midpipe everything is stock with the exception of a two bro's slip on.
Installing a dyno quick shift kit Tommorow R. |
Originally Posted by rhino8648
(Post 1280270)
