Downshifting to stop?
Old May 6, 2012 | 09:02 PM
Dazed's Avatar
Default Downshifting to stop?
Hey,
Just wondering how you guys stop, do you use engine braking most of the time, Or do you pull in the clutch in use the front brake. Or a little of both.
Old May 6, 2012 | 09:39 PM
estate4life's Avatar
February 2012 ROTM
Ultilized all.....
When you pull the clutch (your intention is the shed speed) you must down shift anyway right. So at te same time apply rear brake and front.
Remember if only use engine braking, your tail stop light won't trigger so OP behind you would not know you are slowing down. So okay to engine brake & apply both F/R brake same time....
Now if your going straight...front brake will shed speed fastest, so apply that more for emergency brake.
Old May 7, 2012 | 12:46 AM
ajzcamaro's Avatar
I use the front brake and downshift while rev matching each gear in order to keep the back wheel from locking up. Sometimes I will use the back brake along with the above.
Old May 7, 2012 | 11:06 PM
Steve Theodore's Avatar
I've found that if I get out of the mindset of using my rear brake that I start to never really use it...which is a big NO-NO right from MSF 101 class!
So, I try to practice balanced braking and also downshifting. I'm not very skilled with rev matching at this point though, but it's fine to practice just the same.
Old May 8, 2012 | 02:43 AM
RedBaron's Avatar
Both rev match and brake, clutch doesn't get pulled until I'm almost at a complete stop.
Old May 8, 2012 | 10:52 AM
Conrice's Avatar
msf's 70/30 is for standards and cruisers. it's almost 90/10 on race reps, and it causes the rear ends to lock up more so than not really using it - so it's not really as big of a no no as you think
Old May 8, 2012 | 06:01 PM
Ironhead's Avatar
The 954 has a rear brake? : )
Old May 12, 2012 | 11:25 PM
GorgeousHellion's Avatar
Maybe I missed something...
Old May 13, 2012 | 02:01 AM
Wisconsin's Avatar
How do you know what rev's you should be at for each individual gear?
Old May 13, 2012 | 09:36 AM
Conrice's Avatar
it's more of a blip of the throttle. and when letting the clutch out just after a blip, it'll match the rpms.
if you held constant throttle, you'd have to know the exact rpms, but when you blip, the clutch essentially matches it for you.
it's a timing and feel kind of thing. you should have been taught that in msf
