converting torque percentage into ft. lbs.
I recently did the 520 conversion on my 954rr going 15 front and 45 rear which is -1,+2 over factory. Using this formula from calsportbike.com ((new rear/new front)x(old front/old rear)-1)x100 I gained 11.6% more torque over factory. I want know how to convert this percentage into ft. lbs. of torque. Before going -1,+2 I simply plugged in the numbers to see what is more effective if I only changed one sprocket. By going -1 in the front alone I gained in the neighborhood of 6% increase over stock. By going +2 alone in the rear I gained a mere 4% increase. As everyone knows it is more effective by a small margin to change the front sprocket. Just a cool formula to prove that point. If anyone has any input or ideas how to convert percentages into ft. lbs. please share.
cbr, convert, converting, foot, ft, ftlbs, lb, lbs, percent, percentaage, percentage, pounds, precent, torque, torquepercentage
