Clutch probs/?
Old Apr 17, 2008 | 06:10 PM
ImSlo's Avatar
Default Clutch probs/?
03 954. Im getting some slippage 2-3 and a little of 4 under WOT. No matter wherethe engagement adjustment is at. The lever itself does not go all the way forward after i shift. Maybe less than a half inch of space. Seems when i push the lever foward under WOT itdoesnt seem to do it. Could the cable be stretched out enough to where its not pulling the clutch lever back and keeping it somewhat engaged?? Let me know what you think as i just got this and it is pissing me off. Gauge reads 3800 miles which is supposed to be original. I just dont think the clutch would be bad.
Old Apr 17, 2008 | 06:44 PM
ImSlo's Avatar
Default RE: Clutch probs/?
Anyone?
Old Apr 17, 2008 | 07:38 PM
txsmainevent's Avatar
have you tried to adjust your cable at the clutch cover? if your cable is stretched is very inexpensive to replace. try adjusting the cable first to get some "slack" outta that lever
Old Apr 17, 2008 | 08:31 PM
ImSlo's Avatar
thanks for the reply. I havent tried adjusting it there. Will do it tomorrow
Old Apr 19, 2008 | 01:20 PM
nikos's Avatar
It also might be the oil. If you use the wrong oil, it can ruin the clutch. The wrong oil is oils that are labeled as having 'friction modifiers'. As long as you use motorcycle oil, it shouldn't be a problem...
Start with adjusting the clutch cable. Check your oil level and the type that you used last time you changed it next.
fender717
Mar 18, 2008 03:01 PM
dwhite645
Sep 21, 2007 07:25 AM
slimmyslim1420
May 27, 2007 03:07 AM
apj
May 12, 2006 07:05 AM
prkinlotF4i
Dec 22, 2004 02:50 AM
