Is this a Clock? and how do I set it?
Hi All
OK guys n gals b gentle please Please look at attachment highlighted area is this a clock? http://img190.imageshack.us/img190/9210/img3894p.jpg And how do I set it? Have looked through Haynes manual and can not find any reference to it Help a newbie please |
pic no worky
O sugar I tried to post it at imageshack, it gave me url I just copied HELP
yup thats the clock, the two buttons below it, if you hold those down for about a second or two, it should start blinking and then you can set it using the same buttons. Once you click through the hour and min, it will stop blinking. If you need to redo it, repeat :) Hope this helps out, I had the same issue when I first got my bike.
Cheers pal.... i was going to ask this question, so you beat me too it !!!
ya, it's a PITA, and holding the buttons alone (which will happen sometimes even when you're trying to hold both of them if your timing isn't right) will change your units between metric and SAE. so be careful you don't go from Fahrenheit to Celsius or kph to mph.
They are all pulling your leg! That is a Warp Speed Indicator. The 954 standing still is at Warp Lvl 1.....
HA. I had the same problem.
Hi All
Thanks for the help When it stops raining I will open my garage up, unwrap her and give it a go. Cheers :icon_beerchug: |
| All times are GMT -5. The time now is 06:14 AM. |
