Charging issues
With bike running at 5k rpm you should have around 15.5 volts at the battery. If it low then either stator is bad or wires damaged coming from the stator. If rectifier is bad you will have too high volts at battery which will burn up the battery. Battery should have around 13.4 volts with bike not running
