CBR IGNITION??
yesterday, i was riding my bike all day and it started up fine. Today i try starting my bike but for some reason when i turn on my ignition switch, you don't hear that fuel pump sound that it makes. I thought it would be my fuel gone bad but i checked it and it wasn't my fuel pump. does anyone have an idea what i could do to check what could be the problem?
RE: CBR IGNITION??
fuel pump might just be going.. or did u check relay?
try this.. when/if the fuel pump does not operate, prop up fuel tank, disconnect the fuel pump connecter - it's black, then turn the ignition switch on and mesure the voltage between the terminals brown is positive + and green is negative - there should be battery voltage for a few seconds, if there is voltage then replace the fuel pump, if there isn't then check, main fuel - 30a sub fuse - 10a, 20a fuel cut off relay bank angle sensor engine stop relay ecm |
RE: CBR IGNITION??
yes i checked all that and there was power going in but i replaced the fuel pump and it stil doesn't work. All fuses and relays are still good. i talked to a buddy of mine and he said it could be my grounding or some sort of wiring malfunction.
RE: CBR IGNITION??
bobjoe usually goes for the technical fixes where I stay simple. First off, the bike is in neutral and the kill switch is on, right?
RE: CBR IGNITION??
well i figure the simple things have been tested/checked out
RE: CBR IGNITION??
yes it is in neutral and the igition is on. Still no sound from the noise when you turn on the ignition switch.
RE: CBR IGNITION??
how do you know it's not the fuel pump
RE: CBR IGNITION??
The diodes in the ignition are probably bad. You PROBABLY need a new ignition.
This only is true if you can get power to the pump and make it prime manually AND you have ran all of the wires to the pump to make sure they are good and their connections are good. |
