Blinking digital clock
Hi - first post here, so please go easy! Sadly it's a troubleshooting question I have that someone here may know the answer to.
Whenever I start the bike up, the digital clock blinks as 01:00. Not just the hour, not just the minute, but the entire "01:00"
I've held both buttons in to try and set the clock, but it doesn't work. If you press just the A button, it changes the odometer a-b (as it is supposed to) and holding it down it resets the odo (as it is supposed to). If you press the B button, it swaps the display of the fuel economy and the kmh or mph (as it is supposed to).
So both buttons work, but I can't get the clock to be set.
All other functions of the clocks seem to work/be fine. I've checked the fuse, and all seems good there.
Any ideas?
Cheers and TIA
Any ideas?
Cheers and TIA
Dont try to set the clock with the bike running, just turn the key. Its a little tricky but press them both togather. A button should be to select hour or min and the B button should change the time. Might be backwards tho. After your done setting it to the time you want just sit there and wait. It takes a little bit of time. Again the only way i have been able to do it was it the engine not running.
no more blinking 1:00 I finally have a clock that works
I bought my 2002 CBR954 in 2008 and had the blinking 1:00 ever since. I had tried the owners manual and always lost the time. I guess they should have mentioned waiting in the manual. Now I finally can ditch the old wrist watch on the handlebars because of this forum. I wish I would have looked 2 years ago. You can see how much this bothered me to still try again after this long.
