better mpg with 17T front sprocket??
[hr]
I have a 520 conversion (15/43) fitted on my 954 and have been averaging 43-46mpg. Its doing almost exactly 6000rpm at 80mph. I would like to go to a 17T front sprocket which would lower my rpm's by almost 12%. Anyone tried this? Will it fit?? Will it make the bike lose too much punch??[/align]
RE: better mpg with 17T front sprocket??
I guess I just don't see this as sucking the life out of this rocket. Maybe I'm not as much of a speed demon as some of you guys. I never have enough road to open this thing up completely in first gear, maybe the steep gears would allow that. At any rate, only a $25 experiment so worth a shot.
1400rpm, 1st gear
Stock gearing 9mph
+1 gearing 10mph
-1 gearing 10mph
4000 rpm, 1st gear
stock gearing 26mph
+1 gearing 28mph
-1 gearing 25mph
4000 rpm 2nd gear
stock gearing 37mph
+1 gearing 39 mph
-1 gearing 35 mph
1400rpm, 1st gear
Stock gearing 9mph
+1 gearing 10mph
-1 gearing 10mph
4000 rpm, 1st gear
stock gearing 26mph
+1 gearing 28mph
-1 gearing 25mph
4000 rpm 2nd gear
stock gearing 37mph
+1 gearing 39 mph
-1 gearing 35 mph
ORIGINAL: gearhead
1400rpm, 1st gear
Stock gearing 9mph
+1 gearing 10mph
-1 gearing 10mph
4000 rpm, 1st gear
stock gearing 26mph
+1 gearing 28mph
-1 gearing 25mph
4000 rpm 2nd gear
stock gearing 37mph
+1 gearing 39 mph
-1 gearing 35 mph
1400rpm, 1st gear
Stock gearing 9mph
+1 gearing 10mph
-1 gearing 10mph
4000 rpm, 1st gear
stock gearing 26mph
+1 gearing 28mph
-1 gearing 25mph
4000 rpm 2nd gear
stock gearing 37mph
+1 gearing 39 mph
-1 gearing 35 mph
Give it a try, but it could become more costly in the long run... First. it WILL take off like an electric wheelechair. second, it will be alot harder on the engine and especially the clutch. Have you priced a clutch lately? Did you think that the rpm could be so low that you could be lugging your motor, this causes more stress on internal components, not to mention the constant shifting. These bikes are ment to run within a certain rpm when cruising, this keeps oil pressure up and heat down. Andwhy would youneed more than43-46 mpg? This is a sport bike... You want miles per gallon- get a honda 90. imo...
