954 Fan Relay switch
OK my next project is the radiator fan cooling relay bypass switch.
any one have a link or write up on the parts and a how to on a 2002 cbr 954?? Thanks dudes |
It's as easy as it gets.
1)Go grab a couple of quick-splices from autozone and a 10A rocker switch. 2)Decide where you want the switch to go. 3)Quick-splice into your license plate + wire, and run the other end of that new wire to the switch. 4)Quick-splice the fan + wire, and run the other end of that new wire to the switch Done. If you do it like I just said, You can further complicate the wiring and the switch based on how inconspicuous you want to make the switch mount and wiring, how weather proof you want to make it, or whatever you want to do. I've done it many times, epoxying a rocker switch into the back of the headlight, making a 7/8in. mount for the handlebar, to even relocating the Horn and putting a new on/off switch where the Horn button use to be. But that's the gist of it. No write up needed, even if you're new at mechanical/electric stuff. And there's certainly no reason to by the "kit" and spend $80 or however much they want to charge for it considering you can DIY for $6. |
1 Attachment(s)
Ok one fan bypass switch complete .
Conrice was easy but I took my time and did an OCD job as usual (2hrs) but very happy with this mod ! Rode to work this morning and parked and idled for a few & when temp was 190 Flipped switch and within 60 sec dropped 5 degree's Attachment 24346 |
Great - it looks very clean and inconspicuous. I'm glad its working for you. I'm in SWFL, so like you, I need all the help I can get when it gets hot.
