2003 cbr954 not starting
Old May 3, 2017 | 05:47 PM
Jakob Simmons's Avatar
Default 2003 cbr954 not starting
so ive had the bike for about 4 months and when i got it the previous owner had made custom ignition and kill switches and a couple other things so i tore the bike down and the harness out and fixed all the bad wiring i could see and put the stock ignition controls on and wired in a new ignition (from a cbr600) and with a zener diode (with no resistor) to turn the system on. The thing is that is ran very smooth before i did all this and i changed the spark plugs too but now my problem is that it will only start after a week of sitting and it will only run with the help of the throttle and if it dies it wont start again. Its also fouling the new plugs i just put in and i have codes 8, 9, and 12 is this common or what should i do i am very limited on tools now too
Old May 5, 2017 | 05:40 AM
deaks25's Avatar
Might be worth you downloading a copy of the workshop manual. It has the codes in there, Section 5-10 & 5-11. No matter what bike I have, if I can get a Haynes & an official workshop manual, I do so. Both are always useful to have to hand.
https://www.manualslib.com/manual/81...02.html#manual
So Code 8 is:
Loose or poor contact on TP sensor
connector
Open or short circuit in TP sensor wire
Faulty TP sensor
Code 9 is:
Loose or poor contact on IAT sensor
Open or short circuit in IAT sensor wire
Faulty IAT sensor
And Code 12 is:
Loose or poor contact on No.1 injector
- connector Open or short circuit in No.1 injector wire
Faulty No.1 injector
Sounds Like there's a load of things that aren't connected properly, or haven't been reconnected. Probably means you having to dive back into the wiring loom to check all those connections.
Old May 5, 2017 | 09:07 AM
Conrice's Avatar
Yeah, I would bet the connectors aren't seated properly. Most things like this are a really simple fix when it didn't do it before
simple guy
Jan 15, 2011 02:12 PM
ldiran
Jul 17, 2007 12:02 PM
aaks38
Sep 6, 2006 04:10 PM
