wheelie prob.
ORIGINAL: j61929
Thats the thing tho. All I do is clutch it. I d rather clutch it than bounce it. I ve never bounced any of all the wheelies I ve ever done. Specially on my 636! But it feels like my second gear is very tall. Im assuming that you are saying it is possible for this bike to be clutched up in such a low RPM. What speeds or RPM do you attempt yours on? Cuz if you are doing them almost at the same time and way I do mine, then maybe it is my technique or just minor adjustments need to be made to my clutch lever ( comfortable height and position ).
ORIGINAL: NINE2NINE
the problem isn't with the bike. the problem is that you're trying to do 2nd gear wheelies at 45 mph. way too low in the rpm's. the gearing change will cure this but if you want to wheelie 2nd gear at slow speeds with stock gearing you have to be willing to clutch it up. or do a throttle chop/bounce then wide open.
ORIGINAL: j61929
I thot bout that but I shouldnt have to. you know what I mean? I just really hope that there isnt anything wrong with it. I also wanna know if its like this with everyone else with a stock 929? Ofcourse, 1st gear is no problem but Im stumped on 2nd. But maybe l will just go ahead and get the gearing. Thanx for the response tho. Take it easy brother....
Yeah I think Im gonna go ahead and do the gearing. But nothing too drastic. You mentioned yours was at -1/+2, how much top-end did you loose? and is the added torque very noticeable? I mean ofcourse I want more torque but nothing like a 52t rear sprock. Dont want anything squirly. Not really into shifting during the process either but thanx for the suggestion. What would be the ideal upgrade regarding sprock. size? Thank you everybody.....
ORIGINAL: j61929
Hi, I wish I had the ability or option to attempt either a sit down or a stand up wheelie's on my current bike but my mates have tried the following to get their front wheels higher for longer.
Lighter Wheels
Shortened the swing arm
Put a bigger sprocket on the back
Improved throttle response (balanced carbs/power commander)
Although my mates invested the money wisely upon the machine I have found that when the missus is on the back of my bike the front wheel pops up when accelerating hard.
So the cheap option is to get yourself a pillion and a female one is preferable and one that can ride a bike back from the pub is even more advantageous.
An old freind has a 929 and I remember he could pull wicked wheelies in 1st but as soon as it got to 2nd the front wheel just came down, if I remeber correctly he had the clutch plates changed upon the suggestion a track day organiser dude.
Lighter Wheels
Well on a 929 you should be able to pull up 2nd on it bone stock at 45mph no problem. Forget gearing and all that crap, theres something else wrong...If I can clutch up my F4i at 50ish you should be able to do the same on your 929. keep practicing get stock on lock before you gear it and all that.
ORIGINAL: AzNBoI_585SF
Well down here anyway a baseline dyno run is $30 and it will show a slipping clutch as well as wether you are leaning out or too rich in the rpms you are using,one way to kill several things at once and like I said a baseline is just a couple runs checking it all over and will give you specifics you won't get elsewhere.Example I had a bike ran great verified no clutch slip but was down on power,exaxtly 25% down from last years run,well 4 carbs 25% sure enough one carb had a torn diaphram and I was pointed there by a $30 dyno run. HTH
