Valves
Old May 7, 2007 | 01:37 PM
929BEATSTI's Avatar
Default Valves
I have about 17,000 miles on my 929 and i know you are supposed to get the valves checked at that mileage. What are some signs that the vavles should be adjusted.? I am starting to hear a little bit of ticking along with a little rougher idle. Thanks
Old May 7, 2007 | 08:57 PM
QuinC's Avatar
Default RE: Valves
I talked to a bike mechanic a while back and he said that he did his at 30k and they didn't need it. he says not to even worry about it tell your around 50k.
Old May 7, 2007 | 09:14 PM
the greeen lantern's Avatar
Default RE: Valves
a little preventative maintence never hurt
Old May 7, 2007 | 11:18 PM
jcowick's Avatar
Default RE: Valves
16 or 17 thousand,, dont know about you but i ride a good bit and that would take me at least 3 to 5 years if not more so its probably not to much to do every 16 or 17 thousand is it?
Old May 8, 2007 | 02:11 AM
mark5009's Avatar
Default RE: Valves
Hi ..
My "new" '01 929 has 56k kms (35k miles) and my mechanic
says that they don't need it. These motors are -really- strong!
Old May 8, 2007 | 04:43 PM
QuinC's Avatar
Default RE: Valves
a little maintance is fine and if you have the money to do a valve job every few thousand miles more power to ya. if you do one you might as well put some performance cams in as well
Old May 8, 2007 | 11:09 PM
929BEATSTI's Avatar
Default RE: Valves
so pretty much dont worry about it? Will it hurt the engine running it with the valves out of wack?
Old May 9, 2007 | 05:23 PM
SUPERMAN_ON_929RR's Avatar
Default RE: Valves
I agree with the lantern a valve job should be $150 at the most (purely adjustment) $150 as to a junk 929 you be the judge.
Old May 9, 2007 | 05:34 PM
Tahoe SC's Avatar
Default RE: Valves
wow...$150 is very cheap...but it does vary depending on where you're at.
in socal, it'll run about $300 just to check, then more to adjust.
the shim under bucket on the 929 is total bs crap design...
as for needing valve adjustment at 16K, it's hard to tell...most likely no, but if you're bouncing off the rev limiter all the time and hammering the **** out of the bike all the time, then yes.
it's not so bad to do yourself. make sure you synch the throttle bodies while you're at it. it'll make your bike much smoother.
Old Jul 2, 2007 | 04:39 PM
nc600rr39's Avatar
Default RE: Valves
how much would it cost to get the valves adjusted by a bike shop?
