undertail for sale
just thought I would throw it in here since this thread is bike specific
https://cbrforum.com/m_502871/tm.htm
sounds like yours is a little different than mine, at least the lights anyway. mine are LED's so there is very little if any heat; certainly not enough to melt anything.
custom dynamics makes a LED cluster with integrated blinkers that are about the same size as the LED's that came with this tail section
the LED's that came with my undertail were pretty weak. when it comes to brake lights, I'd prefer some that has some *** to them.
here is the cluster that the undertail came with:
![](http://ibkevman.com/v-web/gallery/albums/album68/DSC04515.jpg)
these are the ones from custom dynamics:
![](http://www.customdynamics.com/Images/3FunctionSmFINAL.gif)
48 LED's vs. 9 makes for an obvious difference
i'm telling ya, the difference is night and day. custom dynamics were great to work with. I think the dude's name is dave I worked with. I used the existing tail light housing piece, popped out the existing LED cluster, opened up the housing piece a little to make room for the new cluster, and shoved the new one in. make sure to ask for the 4-wire pigtail when ordering.
you won't be disappointed
ORIGINAL: goldenboy929
i was just looking at them 81 dollars isnt that bad campared to being smashed in the rear cuz someone cant see you what size did you order
I have the eurobikes undertail wich looks just like the one posted above, MIne has the same porblem as to being VERY dim.
I was told that the 1156 will work for my 1157 lights i have now.
Another thing im not sure if you have the same problem or not, When i turn my signal off there is a 2 sec interval before the taillight comes back on.. I was told its because of the controller im using, BUT with the dyn-clus i can complete eliminate the controller and there will be no time that the light is not lit.
