Stand question
RE: Stand question
I have the same stands. All I did was flip the pads around so that the pads are used for the swing arm not the spools. I had to raise the right side all the way up and lower the left side down alittle until the bike was perfectly level. The stands work great. PM me if you need any extra pics or anything.
RE: Stand question
I've got the same stands... they are great. I'm not sure if it is because I didn't adjust them properly but I notice the right side seems like it has more stress on it. Would you mind throwing up a couple more pics of your setup so I can try to adjust mine, it would really help me out!
Thanks
Thanks
RE: Stand question
Ok, I got some pics for you guys. I hope this helps you all out. The flush mounts I actually purchased from superbrightleds.com for $9 a piece. You have to take the stock turnsignal off the turnsignal stay and screw these leds into the stay. They sell the same lights on ebay for $45+ from what I've seen.
Bike perfectly level on rear stand
Difference in height from left to right side
Right side
Left side
Rear pic on stand
My turnsignals, mine are armber I would suggest the yellow they are alittle brighter.
Right side
Left side
Rear pic on stand
