sprocket sizes?
Old 03-30-2006 | 01:31 AM
stanghater's Avatar
Default RE: sprocket sizes?
so i went and counted mine, i have 46. What does this mean? how can i tell what chain it is? My speedo is waayyy off
Old 03-30-2006 | 01:49 AM
Y2K929RR's Avatar
ORIGINAL: stanghater
It means whoever had it before you changed the rear sprocket. Unless he installed a speedohealer or other speedometer correcting device, your speedometer is off about 7% (reading too high). Check your front gear, you may have a 15T up front as well. If you have a 15T front with the 46 rear, then your speedometer would be off about 14%.
As far as the chain is concerned, a 520 is thinner and lighter than the stock 530. If you compare it to a stock bike and yours is thinner, then its most likely a 520.
Old 03-30-2006 | 11:54 AM
sixs929's Avatar
SprocketSpecialists.com offers a split rear sprocket that doesn't require removing the rear wheel, but you gotta remove it anyway in your case to get the old one off! So it's your call - and SprocketSpecialists ain't the cheapest around.
Paulie
10-12-2012 01:02 PM
Phantom F2
F2 Tech
18
05-06-2012 01:08 AM
OffRoadYota
11-29-2008 01:33 PM
eurobeaner
03-08-2008 06:22 PM
wheelieit
08-19-2007 02:57 AM
Quick Reply: sprocket sizes?
