Second gear sucks!
Old 03-10-2021, 08:45 AM
That is one seriously quick bike!
Every Credit
Old 01-18-2022, 06:39 PM
chobes's Avatar
Originally Posted by backdoc
If you want to completely eliminate this problem you need to have the transmission undercut. Did you replace the shift drum when you replaced the shift fork? Also check the teeth on the shifter rod for wear where it engages the shift star. You only have to remove the engine and split the cases to remove the gears in the transmission. Everything else can be done with the engine in the frame by removing the clutch and oil pan.
https://cbrforum.com/forum/how-103/c...cement-151699/
https://cbrforum.com/forum/cbr-954rr...ission-152834/
Is the process for replacing shift drum and forks the same for other Hondas, F3 in particular?
MaikuMizu
F2 Tech
10-03-2012 11:49 AM
neely321
06-03-2008 05:49 PM
kona200244041
03-31-2008 09:31 PM
Scrufdog
10-10-2007 01:35 AM
T02F4i
01-27-2005 03:43 AM
Quick Reply: Second gear sucks!
