running problems
Old 04-22-2008, 11:27 AM
RYDINRED929's Avatar
Default running problems
got my bike out the other day and was riding and after awhile i was just riding down a straight road and it started to cut out and bounce around on me. So i thought maybe i wasnt paying attention and closed off the throttle so i didnt worry to much about it. Well i got it out today and after about 10 minutes it started doing it again. It got more and more frequent the farther away I got. I then came to a stop at a traffic light and it died on me holding the clutch in in 1dst gear. I went to take of and it died again. So i pulled in a parking lot and started it in neutral and put it in 1st and it died. So i re-started it, put it in 2nd and it took off! I got about half way up the hill in 2nd gear and itstartedto cut in and out and then it died!So once gain i started it back up and took off and it was fine until I got to the top of the hill and in 3rd gear i died so i oulled in the clutch and coasted...... Im clueless, I have zero idea whats going on besides possible a fuel pumpissue, maybe faulty ground or something? anybody have any ideas other than that? if i cant figure it out im going to take it to the honda shop and getit taken care of which id rather not do!any ideas before i have to do that?
Old 04-22-2008, 03:23 PM
NY Erion929's Avatar
Default RE: running problems
Did you change anything or replace anything recently, maybe you left something loose?
When it dies and you resart it does it start right up?
Old 04-22-2008, 03:38 PM
when it dies it does start right back up! no problems with that.. i just rode it again and it didnt stutter until about 1/2 hour into my ride and it only did it 1 time, but it didnt die this time..
Old 04-22-2008, 03:58 PM
Is this the first few rides in a while? if So maybe fill it up with some fresh gas then open her up a little bit on the highway..
Old 04-22-2008, 04:20 PM
i knew someone with a similar problem. his zx9 cut off on the highway. i came to look at it and it would start fine but everytime he put it in gear and/or take off , it would cut off. he had a bad kickstand switch so i bypassed it and it was cool. worth a check
Old 04-22-2008, 06:47 PM
i actually just replaced the kickstand switch... the only reason i dont think that is it, is because when i had that problem it would die in every gear no matter what as soon as i put it in gear! its not doing that, its intermittent, when im riding in gear.. i was kind of thinking what NY is thinking.. Im going to check the plugs and put some fresh gas in it and see how it acts.. if anyone else has had any problems like this lets hear them, so i can try to get this worked out! thanks for quick responses, i really appreciate it!
Old 04-22-2008, 07:50 PM
sc929's Avatar
Fuel filter, do we have a filter, never looked. Maybe the regulator, line to the reg. Just ideas.
Old 04-23-2008, 03:12 AM
yeah, its on the pump. i never knew until the other week
Old 04-23-2008, 06:25 AM
thats good to know... need to check into that, is it inside the tank?
Old 04-23-2008, 08:56 PM
yep
Quick Reply: running problems
