problems sith starting
Old Jan 6, 2009 | 05:04 PM
bajaroots's Avatar
Default problems sith starting
Whats up fellas my brother owns a 929 withhigh milage ,the bike runs great but recently upon start ups sometimes the solenoid kicks in (that whizzing noise before you hit the start button)and sometimes it dont ,he has to keep turning on and off the kill switch untill he hears that whizzing noise ,and even after that it will crank but will not start like its not getting any fuel. Eventually it will start after turning up the idleand a few trys.Rule out bad gas weve rode a few hundred miles and been thru a few tanks in a day anyone had the same prob.
Old Jan 6, 2009 | 07:20 PM
929 RR CBR's Avatar
Default RE: problems sith starting
sounds like it mightbea fuel pump problem, the whizzing you hear is the fuel pump priming up. i would check the fuses and all the wiring connections for the pump, if all thats good then mabey need a new fuel pump
Old Jan 6, 2009 | 10:20 PM
RCR's Avatar
RCR
929 RR cbr is right on. Most electrical items work or don't. Im thinking a bad connection and thats cheaper to fix also
I would start with the battery connections first and then chase down the fuel pump and fuses.
Old Jan 7, 2009 | 02:52 PM
bajaroots's Avatar
thanks a lot fellas will do
Old Jan 7, 2009 | 04:18 PM
Lord Jersey's Avatar
Retired Admin, January 2008 ROTM, Lord of Neon & L.E.D.s
Let us all know how that worked out for you.
LJ
Scorpio_13
Jan 15, 2018 09:50 AM
tomtom
Oct 7, 2011 10:26 AM
kpnupe
Aug 9, 2009 11:33 PM
99offroadrngr
Jul 31, 2008 12:10 PM
JMoney
Mar 5, 2006 06:33 PM
