Picked up used 2000 929rr
Well i bought a used 52,000 mile decent shape 929rr for $1,300 ran when i picked it up and the guy ran it out of gass in-front of me and when we opened up, the tank it smelled like varnish so i know we got bad gas. got it home pulled out the tank and drained it, pulled air box and plugs. checked gap .32 right. cleaned air filter. and plugs, new high grade fuel and injector cleaner installed tank and cant find 1 hose for it? dont know if it was not there or if in the excitement of it all, just dont know but it is not the main fuel line. It is not the two smaller lines it is the biggest of the lines besides the fuel line and not the one that comes off of the 90 deg. tube it is a straight down tube about an inch long? any ways now it wont fire. so i'm thinking clogged filter or fuel rail or injectors. also second gear slips but it's not the clutch was told it's some kind of fork in the tranny and it would be an 1,000 + job to do. any insight would be great.
RE: Picked up used 2000 929rr
that hose your missing is an overflow drain hose. it just runs to the bottom of the lower fairing. its if you put too much fuel in and it runs over where the cap closes there is a hole up under the cap for it to drain out of. just get you a piece of hose and route it to the bottom of the lower fairing. oh and you want it an inch or so lower than the exhaust pipe.
