New member with an on going issue,engine cut off when riding.
Hello to you all. I have had my CBR929rr for a year now and recently when riding it cuts out FI light on and a green light on the Speedo. I dump the clutch as I am usually on the move and it kicks straight back in. It is random and at no particular RPM or gear, however has not done it sitting still on tick over. I replaced the battery, ensured good fuel is in it. Read a few posts and checked the lean bank sensor worked as it should hearing the relay click. I have all functioning lights etc. And no obvious burnt fuses.Any ideas? Oh and kick stand functions as it should with general checks and spring retain it up as expected. Kill switch operates normally when used to stop ignition. I am lost.
When you say that it cuts out, is it shutting off? Have you retrieved the codes?
The green light is your neutral light. Could be a bad switch or wiring, it actually being in neutral, or something internal in the transmission. |
Originally Posted by 74demon
(Post 1321291)
So... I think I got it codes reset, went for a short ride and on the motorway within a matter if no idea as I an literally 2 mins from the motorway the FI light cane on and the green light beside the petrol indicator flashed the bike cut off, I dropped the clutch and she came back to life. Too it straight home as I did not want to get stranded. Jumped the code connector and 2 codes are stored one is 9 and the other 34. So buying a replacement IAT but code 35 has gone leaving only 34, What us the difference? Between 34 and 35? Still have the servo buddy connected. Only thing is both codes the bike should operate normally? ? ?
Think what you have here is a wiring problem, maybe even a sidestand switch issue, as all three sidestand, neutral switch and clutch switch go through the diode (near the fuse box) have a look there first , pull it out clean it ,re-install , if it still happens ,your going to have to have a look at the wiring and associated switches, the other codes are separate to this issue
Originally Posted by CaBaRet
(Post 1321330)
https://cimg9.ibsrv.net/gimg/cbrforu...bdec0c3641.jpg
Its a place to start, see here for a online pdf StephyGee.com |
(Post 1321359)
https://cimg5.ibsrv.net/gimg/cbrforu...f9903c0a6c.jpg
Hi matey just to make sure, slightly different diode but same result |
Hello. So got the diode and replaced it, got the lean sensor and replaced it and also the sir sensor to clear the fault in the ecm. So I took it out for a run to see if there was still a fault and I have either solved one issue or mis identified which light had flashed when I it all goes wrong. Yes, a very embarassing option. So when on the bike it cuts out and a green light flashes next to the key symbol and the FI comes on with the red light next to it and so I dump the clutch and back to life it goes.
So, I read up and still could be an earth or something to do with the HISS. The key is not original which I suspect this may have happened to a previous owner. I only got 1 key with the bike. |
