New To 929 Oil Change Questions
I just bought a 2001 CBR 929RR with 21K miles and I want to go ahead and change the oil.
1st-Do I have to un-bolt the header to remove the oil filter it looks close?
2nd-Someone said a Puralator oil filter for a 350Z will work is this true?
3rd-I dont know if the previous owner run synthetic or or dino oilso to be
so to be safe I'm going to run synthetic. Can I use the 10w-40 Royal
Purple oil that Advance Auto sells for cars? They have it on special
now and will save me about $20 if I go this route.
I know these questions have probably been asked before but I am having trouble with the search function. Thanks in advance.
If you have stock headers you don't have to pull the headers to get the filter out. I have heard of having to pull aftermarket headers though.
I have no idea about the 350z filter, I jus use oem
I doesn't matter if its synthetic or not. Do not use oil for a car as this can cause clutch slippage because of the detergents used in car oil. I have been personally running Shell rottela T 5w-40 diesel sythetic oil with great success for a couple years (diesal oil doesn't have the detergents like car oil) and its only $15 for a big jug. Compared to mobil 1 for bike which is like $15 per litre.
Oh, Lay carboard or lots of rags under the headers when you take the filter off, it will be messey.
I use a strap wrench type tool for the oil filter. I have aftermarket headers and cant get a oil filter socket to fit between the headers and filter.
looks kinda like this:
http://www.classic-car-magazine.co.u...ter_wrench.jpg
also if you're good with tin foil or folded cardboard, you can do the the whole oil change without removing the plastics.
