idles at 4-5 k
Old Oct 24, 2008 | 02:43 AM
atkelley's Avatar
Default idles at 4-5 k
Until I downshift and break, what would cause this?
Old Oct 24, 2008 | 11:55 AM
bignibb's Avatar
Permanent ROTM Nominee
Default RE: idles at 4-5 k
have you tried adjusting your idle control **** on the right side of the motor as your sitting on it?
its down by the fairing and clutch cover, turn it one way to raise the idle and the other to drop it, i cant remeber which way does what but im sure youll figure it out quick enough.
Old Oct 24, 2008 | 07:48 PM
NY Erion929's Avatar
If it starts and idles fine, but wont come back down to an idle after reving it, then maybe the throttle cable is sticking or the throttle tube (under the grip)
Old Oct 26, 2008 | 04:10 PM
atkelley's Avatar
Yes it starts like normal but acts like the cable is sticking, but I dont think that is it, seems like a sensor issue but I could be wrong.
Old Oct 26, 2008 | 08:15 PM
pawnman's Avatar
ORIGINAL: bignibb
thats funny because on my 929 the idle control **** is located on the left side when sitting on the bike...
Old Oct 26, 2008 | 08:39 PM
bignibb's Avatar
um........... i guess i confused it with my other bike well either way try that phantom location switching side ****[sm=yikesomg.gif]
Old Oct 27, 2008 | 02:01 AM
RCR's Avatar
RCR
ORIGINAL: atkelley
I would start with the cables and linkage first(as NY stated). Sensors work or they don't there is no in between, work sometimes and not. most likely just grit binding the cables just enough that it doesn't slide back as easily as it used to.
Old Oct 27, 2008 | 06:29 PM
atkelley's Avatar
Tried it while watching the butterflys, thay are closed and it slowly retitnd to idle maybe it was cable bind ill drive it tomorrowto see if it quit fore sure.
Old Nov 6, 2008 | 02:08 AM
shizz's Avatar
i had this problem on my bike and it was the wax valve or choke valve it is underneath the intake by the idel screw, clean that "take it apart"it will have coolent flowing threw it and it just gets build up and sticks open a lil
zbonfilio
Jul 6, 2010 02:39 PM
prowheelie92
Jan 30, 2010 12:11 PM
mach5
Sep 27, 2009 08:54 PM
Outlaw 954
Jan 9, 2009 10:17 PM
afshooter
May 4, 2006 06:39 PM
