How Much
Way too much going on in that picture to be able to say for sure. You can see some of the "cosmetic" things but you can't tell if the frame is cracked/bent, what the forks look like or the rear section. Does it run? If it does and there isn't anything wrong with the engine, to be safe, that is all that you are really getting for your $$.
__________________
__________________
Just because it doesn't start doesn't mean it won't. In other words, the wreck could have messed up something else that prevents the bike from starting. Like CaBaRet said, you just have to tear it apart and see what you have. If you can get the engine to run, it should be worth the $600.00. Assuming everything else is straight and no cracks, you should have a good candidate for a street fighter build.
bucki4lyfe
05-25-2013 10:50 PM
