high idle
I have an 01 cbr 929rr. I just started experiencing problems wit a high idle. I start it up and it runs fine but after a few minutes the idle should come down but it stays at about 3000 rpm. I think it might be in the thermostat or radiator but I have no idea. Anyone experience this problem ever? If so any help would be appreciated. Thanx
RE: high idle
Hi mate it has nothing to do with your rad or thermostat have you tryed the idle control screw under the left hand side of the tank i could be that simple or yoy could have a sticky butterfly
RE: high idle
I found a conversation on this topic on another site.
I would have suspected the so-called "Fast idle wax unit" which senses coolant temp and influences idle speed. ( by the way, joe200803 is absolutely right - definitely check the warm idle speed and attempt an adjustment with the idle screw - no tools needed, it's the big knob on the left side of the bike, just under the upper frame and just behind the engine. If it's grossly mis-adjusted, it will override all the automatic fast idle controls.) On the site I mentioned, though, somebody said they suspected the wax unit, but another guy urged them to have the start valves synchronized first. I read the procedure for that in my manual, and it's probably best left to a shop. Vacuum gauges with adapters and tachometers involved - also have to lift and support the front of the tank, etc etc. Hope this helps. |
Coolant
Originally Posted by philalsp
(Post 39948)
| All times are GMT -5. The time now is 01:31 AM. |
