Help with my CBR929 Fi light on problem
Hi
My CBR929 having Fi light on now, don't know why? engine runs not very smooth...but still can ride, I have powercommender III with it. any one who can help me to find the error code? thanks a lot//please help |
do you know how to get codes off it.
if not i'll tell you if so what code, if any, is it showing i'll be able to point you in the right direction at least |
Originally Posted by rep929
(Post 773279)
if not i'll tell you if so what code, if any, is it showing i'll be able to point you in the right direction at least Hi On the speedmetor that shows Fi and onw the down side red light on all time.... I don;t know how to get codes. please help m eout.. |
to get the codes stand bike on the kick stand turn the ignition switch to run and the key to on, but dont start the bike. the red light should start to flash. one long flash is equal to 10 and a short flash is equal to 1.(i think a long flash will be about 4 seconds or long so, and a short flash will be just one second long) so if you get 2 long flashes and 7 short flashes that would be code 27. and if you download the manual it will tell you how to do this and it will also have a list of the code numbers and what the code is. its been a while since i had to pull a code frome my bike but this is how i remember its done. if im wrong someone please correct me.
thanks Joe..
where can I download the manual? My light just light-on..not on flash....and speedmotor shows Fi message... |
see the link below for manuals
constant red light on = 1)short circuit in service check connector wire (that little guy under the seat) 2) Faulty ECM sorry man. |
Originally Posted by packdog
(Post 773832)
constant red light on = 1)short circuit in service check connector wire (that little guy under the seat) 2) Faulty ECM sorry man. Thanks man.......... really appreciate. |
(Post 773832)
im looking at the service manual i downloaded and it is section 5 as shown on the lower corner of the page. on 5-8 it starts talking about the testing procedures, and on 5-12 says what all of the codes are and what numbers they are. hope this helps. good luck
Thanks man....
I got it... |
