HELP with headlights..brights work but not dim?!?
Old Mar 13, 2007 | 12:28 AM
mkfoxxx's Avatar
Default HELP with headlights..brights work but not dim?!?
Ok...I noticed today riding around that my headlight wasn't on. I I switched to bright and my brights came on. So, I figured the bulb was bad. Went to Advance to pick up a bulb(s) for extra and installed it. Again, all brights but still no dim headlight. Ok, I figured, its just 20amp fuse. Nope, i was wrong again. So, being the skilled electrician I am I trouble shot. First checked the volts to the light connector, 0 volts. Second, the volts coming thru the fuse....NOTHING. The wierd thing is that everything else works, I mean everything except the running/middle/dim headlight. I thought it could have been fro mthe undertail install because my undertail works fine. So, it's a wiring problem somewhere and its BEFORE it hits the fuse box. Please someone tell me that this is a common problem and is a easy repair. I need some help/advice.
Old Mar 13, 2007 | 12:50 AM
Ripper44's Avatar
Default RE: HELP with headlights..brights work but not dim?!?
Had a similar prob last year except no guage lights and only dim.... ended up being a broken ground wire dont know if this helps or not but maybe something to check for goodluck, let us know if you figure it out and what it was ... just incase
Ripper
Old Mar 14, 2007 | 02:26 PM
mkfoxxx's Avatar
BUMP.....still having problems. If you can help please do so. Researching on the net and I can't find anything bout this problem. thanks
Old Mar 14, 2007 | 03:07 PM
Triax's Avatar
It may be the actually headlight plug. Check to see if you are getting any power there.
Old Mar 15, 2007 | 04:42 PM
mkfoxxx's Avatar
no....it is NOT. Like I said, the fuse isn't even getting volts...
Old Mar 15, 2007 | 04:56 PM
Triax's Avatar
THEN TAKE IT TO THE DAMN DEALERSHIP!!!!
Old Mar 15, 2007 | 09:21 PM
Joker_114th's Avatar
Not to Wise,But didya check the Ground.....DOH!!!!!
Old Mar 15, 2007 | 11:49 PM
Ripper44's Avatar
Like i said try checking the ground!! it's easy to overlook the obvious, if all else fails i agree with triax take it in
ORIGINAL: Joker_114th
Old Mar 16, 2007 | 10:34 AM
Illushun's Avatar
Check for continuity in the wires. You have to verify that the wires can handle a current first, before it is just accepted that nothing is at the fuse. Obviously there is something that is not providing power to the fuse. Where is this problem (ponder only). Have you looked at the wiring diagram from the service manual and traced all wires?
Old Mar 16, 2007 | 05:14 PM
mkfoxxx's Avatar
the wiring diagram i have sucks...where can i find a better one?
