Fuel pump won’t prim unless wires to battery
Old Dec 22, 2020 | 06:07 AM
Bikelife1229's Avatar
Default Fuel pump won’t prim unless wires to battery
Hey guys, so I recently put a full exhaust on my 929, changed valve shims ,and when I put everything back together I got no spark. However my fuel pump was still priming, everything worked but no spark. After not finding anything obvious I pulled the whole harness out to check every wire.well all the wires seem to check out . Hen I found the zener diode was giving 10 volts to ecm instead of 9. So I orderd some diodes. Well waiting for them I decide to put the harness back In, and now my fuel pump won’t prime. So I thought maybe since I removed the old diode that could be why. I hooked up a 9v battery and nothing. The fue primes when I wire it to a battery. My relays work , kill switch, all switches work. The only thing I can think of is bank angle and I have it bypassed . The red and green wire. White wire is just wrapped up to it it making not contact.
unnecessary
Apr 29, 2020 04:11 PM
Cody Orr
Apr 19, 2020 01:51 PM
Ls1Mx5
Jan 5, 2014 04:01 PM
kentuckydiesel
Jan 7, 2009 07:24 PM
Katman
Sep 13, 2007 06:02 PM
