-   CBR 929RR (https://cbrforum.com/forum/cbr-929rr-20/)
-   -   Fuel Pump?? (https://cbrforum.com/forum/cbr-929rr-20/fuel-pump-58561/)
kentuckydiesel Jan 26, 2008 10:52 PM
Fuel Pump??
Will a fuel pump from any of the other models fit my '00 929?
ReSpEcT Jan 27, 2008 03:20 PM
RE: Fuel Pump??
929 and 954 fuel pumps are the exact same....And im sure a few others are the same as well....=-)
HAVOC Jan 27, 2008 03:50 PM
RE: Fuel Pump??
dude like i mentioned in your other thread your fuel pump might be fine but there are other reasons that will cause the fuel pump not to prime such as the kill switch and the B.A.S (bank angle sensor.. or more commonly refered to as the "tip" over sensor) check these things 1st and im sure you will find the problem within there
kentuckydiesel Jan 27, 2008 05:37 PM
RE: Fuel Pump??
the pump is definately bad, I pulled it today and tested it by itself, no go.
Honda wants like $370.....uh, no thanks. after a little research, found out our pumps are of the same series made by denso that was used in the mid 90's mitsubishi 3000gt, but the mitsu has a higher flow rate. sounds like an upgrade to me! picked one up at advance today for $130. I'll let you all know how it works. -Phillip
pawnman Jan 28, 2008 12:43 PM
RE: Fuel Pump??
if that doesn't work for you i have a goodlow mile pump i'll sale for $50.00 plus the shipping
