front turn signal adapters
Old Dec 19, 2020 | 02:35 PM
Jjbcbr929's Avatar
Default front turn signal adapters
Trying to hook up my front turn signals. Where can I buy the adapter wires that fit into my harness plug-ins ? My signals have bullet connectors.
Old Dec 19, 2020 | 02:37 PM
74demon's Avatar
Spice in the original connectors from the old lights. Are your new ones 2 wire or 3 wire?
Old Dec 19, 2020 | 02:41 PM
Jjbcbr929's Avatar
The bike didn't have front signals. I bought four 2 wire signals, I installed the rear ones no problems.
Old Dec 19, 2020 | 02:43 PM
74demon's Avatar
Are you willing to cut your harness?
Old Dec 19, 2020 | 02:50 PM
Jjbcbr929's Avatar
I'd rather not but if I did I have a blue plug with 2 wires and a white plug with 1 green wire.
Old Dec 19, 2020 | 02:56 PM
74demon's Avatar
The green wire is the ground. The two wire connector carries the running and turn powers. Since you only have 2 wire signals, the power for the running light will not be used.
Old Dec 19, 2020 | 03:01 PM
Jjbcbr929's Avatar
Got it, I'll see if anybody else chimes in if they have purchased these connectors. I understand the wiring now, thank you.
Old Dec 19, 2020 | 03:35 PM
74demon's Avatar
They won't make adapters for it. You may need to find some broken lights to get the connectors off of to make your own. I'm not sure if a dealer can order the connectors alone or not, but I would check with them. The only other option I see to not cut the harness is to getto them together using the piggy back scotchlocks.
Old Dec 20, 2020 | 02:45 PM
Jjbcbr929's Avatar
I went ahead and put bullets on harness side and got all 4 working !
Turbulenz
Dec 27, 2011 03:23 PM
dream95f3
Oct 26, 2010 07:27 PM
PABlackhawkchief
Jul 17, 2008 10:43 PM
red_devil
May 31, 2007 11:56 AM
link954
Mar 8, 2007 08:26 AM
