fan on all the time
fan on all the time
I bought an 01 929 rr and noticed that before the engine even starting the fun is running as well as after i start it in the morning. I am located on the island of antigua so I was thinking that the sensor for the radiator to kick on failed and someone rigged it to stay on all the time because of the heat. The problem with this is the drain on the battery many times in the morning it doesn't have enough juice to start and i have to push start it. Should the battery have enough juice to support the fan running all the time and I just need to get a new battery or is their a way to bring it back to kicking on at 223? Any help would be greatly appreciated
RE: fan on all the time
i put it on a switch and its better but it still won't crank sometimes i think my battery is just weak my friend has a battery for a cbr 900rr the only differences i found were the height being 4.2 instead 3.7 and the amp hours being 9 instead of 8 has anyone had any success because my seat is modified and i don't think the height should be a problem my seat is high enuff but are the connectors the same? Thanx again
thisismyacct
10-15-2008 08:19 PM
