CBR929RR Fuel Pump Prime Issues - PLEASE HELP!
Old 07-23-2017, 10:54 AM
CaBaRet's Avatar
Originally Posted by antallee
how do i get the wire into the ecm with the little rubber thing inside? should i just cut the wire and tap it on that way?
You could use a paper clip , and push it into the back of the connector, do the same thing each end ,then join the wire to the paper clips
  #22
Old 07-23-2017, 01:27 PM
CaBaRet's Avatar
Ok so i think i may be onto something, the brown wire from the fuel pump goes into the relay, then the relay has a brown/black wire that goes to the ECU. the brown/black wire at ECU has 12v with ignition on, and has voltage right to the relay, but at the relay theres no voltage to the brown wire that goes from relay to the pump. at the relay there is 12v at the other 2 wires also (black/white i think they were?) theres 2 other wires on pump a green for ground and a brown thats for low fuel which goes to the front of bike. The only thing im seeing that would control the pump is that brown wire that has no voltage out of the relay, i did swap the relay and that didnt change anything so it cant be the relay thats bad. If there is 12v coming from ecu to the relay but nothing out of relay to pump what the hell is happening? this is confusing to me. Im not a expert but i understand low voltage and have some experience in electronic repairs, auto wiring, etc so im not a complete noob
The Brown wire only goes from the Fuel Cut relay to the fuel Pump, the Brown/Black wire from the fuel sensor goes to the instrument cluster
Attached Thumbnails CBR929RR Fuel Pump Prime Issues - PLEASE HELP!-fuel-pump.png
  #23
Old 07-26-2017, 01:09 AM
CaBaRet's Avatar
Is the Fuel Pump Inline 3 pin connector ,connected the right way round?
  #24
Old 07-26-2017, 08:41 AM
backdoc's Avatar
Have you checked the right handlebar switch for loose or broken connections? Does the headlight come on with the key and kill switch on?
  #25
Old 07-26-2017, 03:08 PM
CaBaRet's Avatar
Think he's pretty much thrown the towel in Backdoc
  #26
Old 03-02-2019, 11:15 PM
Cody Orr's Avatar
Default Help needed
I'm kind of running into the same problem, bike ran fine today then just died, fuel pump won't prime, checked all fuses, bas, all relays, kill switch, heres the odd part, I have power going to the pump when its not plugged in but when it is plugged in I have no power at the pump itself, swapped out relays still no change, ran pump straight to battery and it kicks on, does anyone have any ideas
  #27
Old 05-13-2019, 08:18 PM
msf0002's Avatar
Lookup “pink wire no fuel no spark” it’s an anti theft device in the ignition that uses a diode to drop voltage to 9v over a signal wire that is sent to the ecu. You can solder in a 2.2k resistor in line on the pink wire that will drop the voltage to the appropriate range. There are many many posts on it and many ways to go about it with diodes and resistors and a combo of the 2. I fixed mine with the 2.2k resistor tho. I’m not an electronics person so I can’t tell you why a 2.2 works but it does. I will try to find a link with pictures if I can find one. I’m gonna have to do it again because I just bought an aftermarket ignition that doesn’t come with the diode. You won’t find any info about it in any official manuals since it is an anti theft device.
Cody Orr
04-19-2020 01:51 PM
edwardzx7
03-13-2011 11:53 AM
kentuckydiesel
01-07-2009 07:24 PM
Di3eZiie
02-04-2008 02:32 AM
hotwyrd
01-31-2008 02:14 AM
Quick Reply: CBR929RR Fuel Pump Prime Issues - PLEASE HELP!
