cam pulse sensor
RE: cam pulse sensor
ORIGINAL: RYDINRED929
i 2nd the fule line neing bent while tank mounted! I had the same problem, didnt think it was the line and ended up making myself look stupid
ok lines looked good so i took the tank off and took fuel pump out gas was good nothing in the take so i looked at the pump and it had metal stings wraped around it "it looked like shaving after you drill threw metal heres a pics this by the filter i pulled it off and put it back together still didnt work same as above start then stop
RE: cam pulse sensor pics now
ok i got it running i checked codes and their was a lot so i erased them and i got it started their was a lot of smoke grey and black it had rough idle it got up to temp and idle some more temp got to 145 so went gave it some gas and it poped out of the exhaust still smoke coming out also idle for a few more sec then died started back up smoke seemed to clear up a little still popping out of the exhaust im going to check plugs does all of the air box need to be bolt back in stacks and all thanks
i know its alot but do you remember what any of the code flashes were? i mean just because your erased them doesnt mean they were fixed. when my pulse sensor when out starting fluid wouldnt even make it start. its sounds like your fuel pump. guess checking the fuel pressure would be a good next move. areyour airbox sensors plugged in?
