-   CBR 929RR (https://cbrforum.com/forum/cbr-929rr-20/)
-   -   Air Flapper mod - HELP (https://cbrforum.com/forum/cbr-929rr-20/air-flapper-mod-help-23438/)
stang54 Sep 19, 2006 10:44 PM
Wondering if anyone can help me out .. I bought a 2000 929 and the original owner had allready completely removed the air flapper. After reading a previous post on how to complete the task, I noticed there is suppose to be a vacum tube that needs to be blocked off... my problem is I can not find the tube, nor can i find the canister / solenid (im thinking he removed all these pieces as well) anyone know where the tube runs from or could be tucked at ( poss. under the air cleaner housing?) The bike starts right up and idles / runs fine... should i assume that he blocked this off if the bike runs proper... thanks...
Reckles33 Sep 21, 2006 12:30 PM
RE: Air Flapper mod - HELP
You could assume that he had capped off and removed the solenid. if the bike starts and runs good big deal, but does the choke work when the bike is cold??
stang54 Sep 22, 2006 05:03 AM
Choke works when bike is cold, warms right up and idle is constant at about 1300 -1400 rpms..
birde Sep 24, 2006 03:41 PM
what is the air flapper mod? and 929s have a choke?
stang54 Sep 24, 2006 04:54 PM
Air flapper mod is removing / or unhooking the air flapper (located above radiator) to allow more air to the motor as opposed to the small two vents that it breathes through at lower rpm's from factory.
birde Sep 25, 2006 02:41 PM
is this better for the 9?
stang54 Sep 27, 2006 08:26 PM
it is suppose to be , thus making it breath better.. there is a post somewhere on this site and i found another when i did a search
Reckles33 Sep 28, 2006 12:49 AM
you know the tube and the solenid could have been part of a Cal. mod. the Direction that you may have used could have been for a Caliy bike. no big Deal.
birde Sep 28, 2006 01:36 AM
can you feel difference without the flappe?r
929 DOUBLE ARE Oct 9, 2006 05:24 PM
yeah you can feel a differance with the mod, and hear it 2:) RPM's go up faster and u'll notice a lil more snap in the bottom end
