Air Flapper mod - HELP
Old Sep 19, 2006 | 10:44 PM
stang54's Avatar
Default Air Flapper mod - HELP
Wondering if anyone can help me out .. I bought a 2000 929 and the original owner had allready completely removed the air flapper. After reading a previous post on how to complete the task, I noticed there is suppose to be a vacum tube that needs to be blocked off... my problem is I can not find the tube, nor can i find the canister / solenid (im thinking he removed all these pieces as well) anyone know where the tube runs from or could be tucked at ( poss. under the air cleaner housing?) The bike starts right up and idles / runs fine... should i assume that he blocked this off if the bike runs proper... thanks...
Old Sep 21, 2006 | 12:30 PM
Reckles33's Avatar
Default RE: Air Flapper mod - HELP
You could assume that he had capped off and removed the solenid. if the bike starts and runs good big deal, but does the choke work when the bike is cold??
Old Sep 22, 2006 | 05:03 AM
stang54's Avatar
Choke works when bike is cold, warms right up and idle is constant at about 1300 -1400 rpms..
Old Sep 24, 2006 | 03:41 PM
birde's Avatar
what is the air flapper mod? and 929s have a choke?
Old Sep 24, 2006 | 04:54 PM
stang54's Avatar
Air flapper mod is removing / or unhooking the air flapper (located above radiator) to allow more air to the motor as opposed to the small two vents that it breathes through at lower rpm's from factory.
Old Sep 25, 2006 | 02:41 PM
birde's Avatar
is this better for the 9?
Old Sep 27, 2006 | 08:26 PM
stang54's Avatar
it is suppose to be , thus making it breath better.. there is a post somewhere on this site and i found another when i did a search
Old Sep 28, 2006 | 12:49 AM
Reckles33's Avatar
you know the tube and the solenid could have been part of a Cal. mod. the Direction that you may have used could have been for a Caliy bike. no big Deal.
Old Sep 28, 2006 | 01:36 AM
birde's Avatar
can you feel difference without the flappe?r
Old Oct 9, 2006 | 05:24 PM
929 DOUBLE ARE's Avatar
yeah you can feel a differance with the mod, and hear it 2 RPM's go up faster and u'll notice a lil more snap in the bottom end
