929rr Outer Clutch Basket won't go back on?
Old Dec 14, 2013 | 07:04 PM
JedGoingHam's Avatar
Default 929rr Outer Clutch Basket won't go back on?
Need help, The gears are not letting me put the outer basket back on? How do i line the gears up correctly? Pictures below.
Old Dec 15, 2013 | 03:58 PM
Conrice's Avatar
Yup, they do that so as to stop the gear lash between the basket and crank. You have to line the scissor gears up correctly with a hole that's in the casing by the crank. A screwdriver in that hole + pressure lines up the scissor gears and the clutch outer will go right back on.
Here's another link with a guy that describes it better than me. AND it's in the manual.
https://cbrforum.com/forum/cbr-954rr...roblem-145573/
Old Dec 15, 2013 | 08:06 PM
Hey Thank you so much, I use the screwdriver and it lined up the scissor gears!
Old Mar 30, 2014 | 01:24 AM
Chefohboy's Avatar
and how did u remove the basket?
Old Mar 30, 2014 | 01:01 PM
Conrice's Avatar
It pulls right out....
Old Mar 31, 2014 | 07:25 PM
Chefohboy's Avatar
ok i have 2 questions. 1 is what hole do i stick my screw driver in.. aheem.. and 2 is that chain behind it supposed to have slack?? look at my post for more info.
hioc1098
Sep 1, 2012 11:56 PM
vdubracer33
Nov 24, 2008 04:33 PM
Mike2609
Jul 13, 2008 07:54 PM
Motostunta
Mar 23, 2008 07:57 PM
