929 with Single Side Swingarm
I made it out of car side moulding by layering it on a fiberglass plug. Its fake of coarse but it made the bug look like an old ****** or 34 ford. I traded this car off a long time ago so its gone but since then I had a chop top ghia that was widened down the middle to accomodate an s10 frame slammed with 20's.....Wish I had pics but never finished the project and traded it off.
2. Must drill out the 929 axle bolt to fit the vfr axle bolt thru it then cut it up into spacers.
3. Must take a 954 triangle and a vfr dogbone to use as linkage by turning the triangle forward over one turn and adjust shock up a click or jack the seat height up or.... make a triangle how you want it out of 3/16" plate steel or aluminum.
There is some work involved but I would totally do it again....
Here is a little more detail on another forum with pics on what I did.
http://www.fireblades.org/forums/str...-so-far-3.html
