Cbr929rr 2001
Old 02-21-2018, 07:14 AM
cbr-dave600's Avatar
Unhappy Cbr929rr 2001
Hi Guys Can anyone help
my 2001 fireblade has a electrical problem Starts and runs and can do this all day long but go out to it the next day and just won't start just turns over, the Mechanic has tried most things Main wiring loom Crank Sensor etc and still no joy, before changing the ECU thought i'll ask if anyone on here has experienced the same faults thanks in advanced.
ps am looking at an ECU unit on eBay and wondered whether a 954 02-03 might fit on to my 929 2001
Old 02-21-2018, 07:57 AM
CaBaRet's Avatar
Before you change ECU have a look at ECT, cam sensor, ignition pulse sensor and have you got a PC on board
Old 02-21-2018, 08:33 AM
Hi thanks for the reply the Mechanic has changed the main wiring loom the crank sensor and the ignition the bike is showing no faults codes either forgive me for sounding dumb but whats the PC? THANKS Dave.
Old 02-21-2018, 09:49 AM
74demon's Avatar
The 954 ecu will not fit or work, not without serious modification anyway.
Does it ever get started, or is this a rode it and hasn't started since?
When it doesn't start, are you missing spark or fuel?
Does it have HISS?
With more info, we might be able to help?
Old 02-21-2018, 09:52 AM
CaBaRet's Avatar
Power Commander Dave, but don't throw any more money at it yet till we've tried to exhaust every avenue
Old 02-21-2018, 10:15 AM
Thanks 74 Demon for the reply it dose have Hiss spark and fuel there when start up the bike seems to start and run ok every now and then mind boggling.
Old 02-21-2018, 11:28 AM
74demon's Avatar
Since it has HISS, it would be cheaper to replace the bike than the ecu and all the stuff needed to make it work.
The next question is, when it doesn't start, what's missing? It must be losing spark of fuel, or it would start.
